banedon wrote:
It's definitely the adapter.
It's true that the adapter does lengthen the total length of the traces from the RAM to the mobo, so in that respect the adapter just might be responsible for some trouble. It'll be best to keep the traces short.
In pursuit of that goal, it would probably have been advantageous to judiciously scramble the address and data lines. For example, A0 of the SOJ RAM must surely attach to one of the address lines of the DIP RAM, but it needn't be A0. Instead it'll be better to choose whichever address pin is closest. You're free to criss-cross the address lines willy nilly, according to whatever scheme seems to yield the shortest traces. And the same is true when it comes to scrambling the data lines. This increased freedom may also lead to a less congested layout... something to keep in mind if you ever do a re-spin of the adapter PCB.
Here's the layout, with the silk screen and other details removed for clarity. My experience is that of a hobbyist, so I could be worng, but I'm not sure a reduction from 8MH to 4Hz is down to slightly longer traces - just seems likele such a radical operational drop.
I was thinking that it's more likely to be a poor solder joint, inappropriate part or faulty part?
Note: The IC's pin 1 is bottom right, where-as the adapter's pin 1 is top left. The bttom layer is flood filled and sued as ground.
